1997 Ford F250 HD 7.3 Diesel 4x4 ,4EOD trans, Upgraded Alternator, Western plow relay, 4-in lift
Hi all just got done figuring out why my truck was loping a little bit thank you CJ now I plugged my scan tool into erase codes and see if there was any other codes and this one came up I just replaced the ICP about a week prior when I was in California because it wasn't working right I still have the original ICP sensor truck runs great . Only at startup did it romp a couple times before I turn the key off and then turn the key waited a couple minutes and then it would turn the truck on normal and not romp .any help is appreciated
