1 - 9 of 9 Posts
Hey guys this is on a 2003 6.0 powerstroke my cruise control stopped working and I have this code does anybody know what part might have gone bad or what I should look for
When you set the cruise, does the green "speedometer" symbol light up on the bottom left of the dash? If not, that's what's throwing the code. Change the bulb, clear the code and you should be gtg
Sent from my Redmi Note 9 Pro using Tapatalk
Replaced bulb still does not work no lights
Have you checked the fuses and relay? Pull them out and test them, fuses can be bad, even if they look good.
1 - 9 of 9 Posts
