1 - 5 of 5 Posts
truck ran fine all day then went to leave work last night put it in gear and on the way out of the parking lot idleing along it kinda chuged a couple times and then smothed out i pulled this code when i got home along with an egr insufficant flow code and that was all it hasnt acted up any today do you think my cps is on the way out?
Administrator
just don't get any cleaner in the ports above the valve (electronics)
I use a glass and fill it with cleaner and sit the valve in it for a while
you can also pull the vale down with your fingers to clean the seating areas
Oh get the gasket kit from ford ..like 10 $$
1 - 5 of 5 Posts
