1 - 3 of 3 Posts
I just had my injectors replaced and have p0278. I had them changed cause that same code kept coming up. I changed the injector harness and no change. Ficm volts stays 49-49.5 v I unplugged the icp and now the code has not come back. I don’t want to keep driving with icp unplugged. If icp is plugged In no code until truck is fully warmed up. Also have installed new icp. I was just hopping maybe someone has seen this before.
icp plugged in
201887
icp unplugged
201888
Also, with icp unplugged, the computer will use reference pressure which is why the 800psi, compared to the 600 psi. Your code is contribution for #6 injector. Check the plug and wiring on that injector, along with the bubble test of course.
1 - 3 of 3 Posts
