I've thrown this code twice, and both times I was cruising about 60. Ironically, I was almost in the same location both times. Anybody else experience this unknown code or have any ideas?
My Mini Maxx has done the same thing. I have only seen it when I am running the KEM 345 thus far. I am on the KEM 275 and it hasn't thrown that code yet.
I was wondering if you got the flo-pro DPF/CAT delete and if so did you leave any of the sensors pluged into the truck but not the pipes?
None of my sensors are pluged into the truck at all, they are still screwed onto the DPF and CAT.
I loaded the KEM 275 and get the same code now. Seems to be no different as to when it comes on after I clear it than the 345 did. I hope someone can get it resolved.
Mine also has thrown the code on the 250, 275, and 345 tunes from the sd card I purchased. Neither the hot damn or 310 beta h&s files turn on the cel. I have not used a code scanner other than my mini maxx to see if theyre are any other hidden codes or anything.
Anybody ever get this resolved ? I got this code tonight with the Kem 345 loaded on my mini maxx . On a side note i never got it with the H&S tunes loaded . seems to be a Kem thing ?
I've never seen it. All my sensors are plugged in, and all the sensors are in the right bungs in the delete pipe except the pressure sensor that is zip-tied to the frame.
mine does it on every kem tune I have loaded on my h&s. It seems to do it most while cruising around 50-60 mph. I just clear it and keep going, I haven't been able to scan it with a scan tool to see if there are any other codes.
We are working on it.It is nothing to worry about and there will be an update that we will come out. If there are any other questions just give use a call.
Please send me an email with the following information:
Tuner type (BM, MM, or XRT Pro)
VIN
Which File(s) it does it with
Configuration of the truck
How you use the truck (i.e. always towing, always empty, etc.)
Any other codes present
I am working on this issue and should have something shortly.
