1 - 7 of 7 Posts
'' fukin boosten''
im sure i spelled that wrong but i have some bad oxidation on the inside holes on my mt classic 2's and i cant get it off it iritates me so bad i wana buy new ones what can i do.
are they clear coated? IF NOT, try cleaning the wheels with an acid wash and a steel wool pad.
u can try "Bar Keepers Friend" which is mild.
or eagle one makes a "etching mag cleaner" which is stronger.
either one will leave a clean base and you will need to repolish.
again, this is only for bare aluminum!!
I believe the MTs are cleared. If they are use a light polishing compound that you would use on your paint then put a coat of wax on 'em.
'' fukin boosten''
well there not so much pited jus oxodised real bad on inside on the holes in the wheels
1 - 7 of 7 Posts
