1 - 7 of 7 Posts
Hello everyone,
A buddy of mine has a 2002 f-250 with some arising transmission issues. over drive light is flashing on and off and it only has 1st gear at this point in time. no reverse or any other gear moving foward. I figured its shot and i know we need a code reader to see what codes its throwing for the light to come on. Just curious if anyone else has had any similar symptoms and what the outcome was.
Thanks
Danny
Discussion Starter #2
well ive found out its only when it get warmed up that it does this. Just went out and started it up and its been sitting over night and it went into reverse fine and shifted through all the gears like normal
Premium Member
if the OD light is flashing. . . . a code has been stored. If it has one gear..... the trans has since gone into limp mod......
break out a good snap on scanner or AE and get the codes read..... more then likely the trans is shot.
What else?
Check the plug on the right rear of the trans, up by the exhaust. When water gets in there it causes corrosion which then makes alot of problems.
Dave
sounds like planet gear
Definitely a rebuild is heading your way.
1 - 7 of 7 Posts
