1 - 12 of 12 Posts
03 F350 7.3L
Has anyone else had their's stop working? How do i replace it?
Resident Idiot
I had the same thing happen to mine on my old truck. The resistors came off of the circuit board. Sent it to a guy on Ebay and got it repaired for like $20 I think. I would check for power to it first but if it has power, that is probably what happened to yours too.
03 F350 7.3L
Mine worked for a little bit when winter started again and went off.
How do i remove it to check it out? i didn't see any screws and i don't want to just start pulling on it without knowing.
Did your compass part ever work? Mine never did, it would either be in the set up mode for the compass or work but not point the right direction lol
Yep that's it "The resistors came off of the circuit board" they are small chip ones that you can put back yourself with a small soildier gun
There aren't any screws just clips, you just need to get your finger under it and pull straight down.... hard and scary but if all goes well it'll come off. Be careful to not lose the resisters once it's loose
03 F350 7.3L
I'll have to check this out.
Village Idiot
Google overhead computer fix...
outside temp will get you a plastic spark plug looking sensor on your front drivers grill.
Steady hands soldering...its a maybe it is a big plastic box looking resistor that says 516 or similar..
i fixed mine then it died again...bought a replacement that is way off calibration on dte....must of had a small tank.
hardest part is gettin console off...,i used the grab and yank hard method...
though after wards there are two small slots you can poke with a small screw driver in the black part of the cubby at the top.
Village Idiot
Scratch that last part your console is different...i would look for screw or tabs..on that.
03 F350 7.3L
03 F350 7.3L
Thank you
1 - 12 of 12 Posts
