I have the same truck just installed the Edge Insight and it is sweet! Running OT,WT,TT, pyro and fuel pressure AutoMeter on the column. By installing the edge you are able to keep the grab handle. The 2 most important things to watch are the Water Temp and Oil Temp, the max difference in temp is 15 deg. if you have temp over that amount the oil cooler may be getting plugged and that is from the casting sand if you do not have a coolent filter installed, and the fuel gauge will tell you what you are running for pressure. Anything under 45 lbs will play havoc on your injectors. Right now i am running 50lbs at idle and 44-45lbs peddle to the metal so i just ordered a Fuel Pressure Spring Kit from ford and i only have 24000 miles on mine. I have the coolent filter installed one change and full on sand, and the temp in oil and water are running 6 to 8 deg. difference. Also installed the Amsoil by-pass and running Amsoil 15w40. Did not mean to ramble, but hope this helps.hey guys its my birthday and my gf just told me to order guages for my truck for myself...sooo im just wondering whats the 3 most important guages i should order.
thanks, aaron
X2!!Edge Insight FTW.
:whs: you can actually monitor up to 7 things but they get kinda hard to read while drivingEdge Insight FTW.
Boost is on your dash, trans is pretty much worthless IMO.yeah i think im gunna go with pyro tranny boost. then later on get the edge insight
