1 - 8 of 8 Posts
went to drive my 2002 7.3 F250 this morning (38degrees) let it warm up only a minute or two, right before i got in to leave, idle kicked up a little, when i went to drive, i only had partial throttle...after a little pedal, there was no increase in power???? something i did, or a part gone bad??? New to diesels so any help would be a great help...thanks....rsbhunter
heck engine light, and i drove it this afternoon, and it seems to be running ok....i'm glad it's running normal, but it still has me curious??????what could have caused it...thanks...rsbhunter
ebpv its normal let it warm up a little longer
:whs:the ebpv stays closed for a while to warm it up. I found this out the hard way. Went to cross a busy road and almost got tboned. With the valve closed the engine cannot breathe. In those temps I would say 5-10 min minimum warm up. But being in southern Az. I'm no expert on cold starts. It was almost 80 today, brrrrrrrrr!
Firefighter/EMT
My truck does this on cold mornings here too. I think some mornings the fuel starts to gell in the lines and it takes a min or two to clear itself up. This happens even after it is warmed up and was plugged in. I just keep giving it constant throttle til it comes out of it. I now add power service on every fill up!!
Thanks for the answer's...this really is the best forum that i have been on...and the ebpv makes sense, i am filing all this info away so i maybe one day can return the favor to a new to diesel owner...THANKS AGAIN:bowfast::bowfast:
Isn't this why we are all on here?? Hope this helped. Good luck.
1 - 8 of 8 Posts
