1 - 8 of 8 Posts
what causes a valve cover gasket plug to get really hot and melt?
Im trying to diagnose a problem, the plug gets super hot and it even melted. Truck runs only on about 7 cylinders
All done now
Are you broke on the side of the road?
You need to pull the valve cover and check for a shorted out wire.
Okay i realize i have some electrical issues, that is what i am asking for. Not on the side of the road, just badly need the truck running correctly.
It was running perfectly fine when i parked it and the plug WAS metled before i put it back together, it didnt just melt when i tried to start it. I noticed it was melted before i even got it all put back together
All done now
I have left them connected and I have disconnected them.
I am going to move this to the proper forum. The 911 forum is for broke down on the side of the road somewhere. I realize you need it running. Probably get more response in the OBS section.
Premium Member
Then you have an issue somewhere with the wiring since it was melted before you did anything.
so you prolly have a short or break in the wiring.
Bad glow plugs is usually the cause of the melted wiring how old are the glow plugs? I would ohm them first before you start replacing stuff more than likely you have a couple bad ones.
1 - 8 of 8 Posts
