1 - 9 of 9 Posts
How hard do you think it is on the mechanical parts??? Even with good batteries and good glow plugs ?
a cold start is always hard on any moving parts oil gets really thick in the cold so i sugest running a thinner oil in the winter there are many threads about oil on here as far as starting if you have good glow plugs and batteries and a good hpop and a good ficm you should have no problems starting in the cold it will sound aweful untill its warmed up so a block heater is always a good idea this time of year as well
Premium Member
Good batteries feeding a healthy FICM fire injectors using a quality motor oil. Starts up just fine.
'05 Excursion
If you can plug it in I'd add an oil pan heater, makes a huge difference.
Sent from AutoGuide.com App
I started a similar thread a few days ago...
6.0 WINTER COLD STARTS - PowerStrokeNation : Ford Powerstroke Diesel Forum
I know what you are sayin.. Sounds so unhealthy when cold starting a diesel in the winter.. totally sounds like its not right lol..
Best suggestions Ive come across from members so far have been:
-Plugging truck in 2-3 hrs before starting
-Cycling glow plugs 3-6 times
-Anti gelling additives
-5W40 T6 oil
-Rev x
-Good batteries
-Oil pan heater (where and what brand can we buy for 6.0)?
-5W40 T6 oil
-Rev x
-Good batteries
No need to cycle the gp's 3-6 times... Let them run awhile then start it... the gp's run for pry a good 2 minutes. I run mine until the fuel pump stops, then turn the key off, then back on, as soon as the gp light goes out I start it. Fires right up even down towards -20 actual temp and not plugged in.
Banned
Took the words rite outta my mouth!
1 - 9 of 9 Posts
