Pull the engine.
So don't even try doing it the easy way just pull the motor? Anything I should know before pulling the motor do I need to take the entire turbo setup out?Pull the engine.
Well how I was reading on the manual truck I have to remove my tranny in order to remove the engine is that true or can I just unbolt it and hold it up with a strap like the automatic trans?Pulling the engine is the easy and proper way to do it. There are a few other options like welding the pan in place, cutting the cross member or fiberglass and epoxy. If you want more of a challenge, flip the truck over and remove the frame. LOL
Ok thanks I guess I'm pulling the motor.Just pull the trans and then pull the motor.......enough said.
The turbo doesn't have to come off nor do you have to remove the DP to pull the motor. Removing the DP makes the install easier.
Sucking down the AC helps. The AC lines are at least 15 years old and might be alittle stiff to swing the compressor out of the way.
Billy T.
[email protected]
True but sometimes you can get away with a half ass job lol. Know I need to find a cherry picker my neighbor isn't home until 2 months that I usually use his engine lift.Doing it any other way is half assing it and you'll probably end up doing it again. Pulling the motor is at most a one day job, not difficult at all.
Better look at it closely.......usually the one ton position is with the boom retracted. You extend the boom, the weight rating goes down.I hope a 1 ton engine picker is enough because I just bought one. Also what is good to degrees it and clean everything brake cleaner?
I was thinking of doing it that way, how does that work have you done it?raise the motor 4 inches
The boom extends far enough to get the motor out, especially because my front end is still apart. I hope to drain the oil tomorrow then start on the motor Sunday morning since I work to late tomorrow, Friday and Saturday.Better look at it closely.......usually the one ton position is with the boom retracted. You extend the boom, the weight rating goes down.
Billy T.
[email protected]
Yes that's what I meant by that, my boom extends far enough out and still has enough weight rating to lift the motor out. I did a engine swap on a 5.0 e150 van I know that the more the boom is extended the less strength it has.The point was that as you extend the boom, the weight rating goes down.
We all know that it extends enough to get the engine (motor's are electric or hydraulic) out.
Then why is it called Ford Motor CompanyThe point was that as you extend the boom, the weight rating goes down.
Because the _motors_ (starter, HVAC blower, wiper, etc. are made by Ford. The _engine_ isn't made by Ford _Motor_ company....Then why is it called Ford Motor Companyoke:
