1 - 6 of 6 Posts
There are a dozen different things. Most likely it is something up on top of the valley or the high pressure oil plugs on the ends of the heads.
You need to clean it up as much as possible and then watch to see if you can see where it is coming from
Premium Member
99 & 00, F350s, manual and auto, Ext & Crew Cab, 4x2 & 4x4, need more room!
Yeah, what @Bugman says.
I had a leak on top of my engine but by the time it found its way out, it looked like the rear main seal.
Check your valley - between the valve covers. if there is oil in there, it's running down.
Welcome to PSN!
1 - 6 of 6 Posts
