1 - 5 of 5 Posts
Have terminator dual pump and the rear pump is leaking from the 13/16 nut angled toward the passenger side head on the top side of the pumps. This is the port opposite where the HPOP lines tie in. I was looking at oring kits on guzzlers powerstroke oring site and there are orings for the othere plugs but this one is not mentioned. Is there an oring for this plug available from Ford and if so then what is this plug called so I can get the right oring, plus if I remove it is there anything behind it that I need to worry about coming out?
All done now
I would give Joey a shout. I bet he could hook you right up.
Going Crazy
yea your best bet is to just talk to joey
1 - 5 of 5 Posts
