Hey guys ive been fixing the leaks on my 97 f250. I had a pretty significant leak coming from the driver side front oil rail plug and I've gotten that fixed. Now it seems like there is oil collecting under the hpop and slowly dripping down the front right side of the motor. I've cleaned and cleaned and reassessed but I just cant tell where it's coming from. I am about to address the fuel leaks I have with an e fuel conversion and it will be a lot easier to see with the fuel bowl out of the way, but I cant run the motor then ( obviously). I did notice a plug in the block directly below the nonservicable plug on the hpop, it seems to be more wet in that area, what is that plug? Quick fill? Anti drain back?
Thanks fellas
Thanks fellas
