1 - 14 of 14 Posts
i have an 03 6.0. today i noticed an oil leak at the exhaust. has anybody experienced this. i recently replaced the sensor behind the motor. i think its the ipr sensor but i didnt have any problems after that til now.
an oil leak out of the exhaust pipe? i had a friends that was dumpin oil out the exhaust. ended up findin out the intercooler blew apart and broke somethin but cant remember exactly wat it broke.
I had a leak in my turbo, chra was leaking truck was blowing blue smoke. Is yours leaking into the exhaust or behind the motor?
"resident smarty pants"
A failed EGR cooler will do this. The coolant will mix w/ the soot in the exhaust and drip - looking like oil.
Are you losing oil or coolant level?
If you still think your turbo is the problem, pull the down pipe.
Have you pulled your downpipe off? If there is oil inside the pipe that will tell you if its coming from the turbo.
Are you talking about the area at the fire wall behind the turbo?
It's leaking where the downpipe meets my catless flexpipe but I am also running 375cc injectors with a stock hpop but the truck is tuned down
I dont do anything with the truck it's a long story why I have 375s but until I can downsize I have to figure out this problem
1 - 14 of 14 Posts
