1 - 4 of 4 Posts
Hi, I am new to this forum but also a member of powerstroke.org. Ive had my truck for 3 years now. Now to my problem Im having problems with the oil cooler leaking. the spot where it is leaking is where the top front bolt bolts onto. The previous owner broke that piece off and jb welded it back on. but I do not know if thats the engine block thats broke off or if its some sort of a cover that can be pulled off. Hopefully there is someone on here that can help me out.
Discussion Starter #2
Okay I found out I have to get the front cover off. So can someone explain how to get the front cover off
I think you need to pull the motor to do it. You could probably "do it" without doing that, but I'm betting it would be faster and better to just pull it. Cheers!
Thanks for the help. I was told it wasn't necessary but I have a feeling its still going to suck either way
1 - 4 of 4 Posts
