1 - 11 of 11 Posts
· Diesel junkie!!!
For those of you still running a factory filter housing, anybody ever have leaks from the fuel heater. I didn't notice until i got to work, no time to investigate yet. Fuel is dripping off of the fuel heater wiring. My first thought was the water seperator but not the case. Is there a seal or gasket to be replaced??? :shrug:
· Diesel junkie!!!
That was the first thing I looked at, not it!!! Those are due also.
· Diesel junkie!!!
Discussion Starter · #5 ·
It isn't the lid either. Unfortunatly, I don't have a garage, so will have to wait till daylight. Hoping it is something simple, and not a cracked housing!!!:doh:
· All done now
I gutted the fuel heater and cut apiece af gasket materiel and completely closed it off. No problems since then. Of course I live in Texas where cold is 40*.
· Diesel junkie!!!
Discussion Starter · #7 ·
Dono if I want to that up here. Tends to get colder than a witch's t!tty, good idea though.
· All done now
Even if not a permanent fix, it will work for the short term until you can fix it for good.
· Diesel junkie!!!
Discussion Starter · #10 ·
Guess I was wrong, the filter lid was leaking. Put a new seal on and she is good to go!!!:cool:
1 - 11 of 11 Posts
