1 - 1 of 1 Posts
i have a 1997 f450 superduty with an e4od 2wd.
so every once in awhile it will hang between 1st to 2nd shift and then suddenly go into gear. And then at tip in to partial throttle it will shift normally, but only go in "halfway" as in it shifts, and lowers the rpm's of the engine down about 500 rpm. if you give it more throttle it will shift again and will drop the rpm's down again.
Does this same "half shift" in every gear, more noticeable in 3rd and 4th.
I recently installed a HD2 tugger kit and it shifts alot quicker/firmer now but before that it had the same problem. changed out the springs in the accumulator body but didnt take down the main valve body to inspect the shift valves.
1 - 1 of 1 Posts
