1 - 14 of 14 Posts
GoNavy!
My brother has a 93' with the OD light flashing.. He just had the tranny rebuilt and now it's flashing the light. He was told that he couldn't read codes with his year on the transmission.
When he is in drive the trans starts off in second and then goes to first real quick and then shifts like normal...If any body has any comments it would be appreciated.
Stone Crusher
Any transmission shop can pull the codes for you. Getting the codes will make correcting the problem easier. It will save you a buck or two in parts. :D
GoNavy!
I'm not sure if this is true or not... Trackspeeder the transhop said they pulled the codes but the problem is still not fixed...
Does the tach & speedO work? Check & see if #8 fuse is blown.
I'll have him check, thanks Garrett.
Stone Crusher
The tranny requires the tach signal for it to shift properly.
1 - 14 of 14 Posts
