1 - 8 of 8 Posts
Copied over from my build page but thought it might get a little attention over here too.
Well after driving my shortened wheelbase truck a little I have realized that not doing a rsk with sd leafs while I had the front end apart was a big mistake. The combination of the already stiff suspension and the shortened wheelbase has caused the truck to ride like a brick. The truck is so stiff going over bumps it'll knock you out of your seat.
I do love driving the truck, just not on roads with ANY kind of bumps....
I have to get this corrected above everything else so I have researched and come up with a few observations. I really like the PMF kit and will more than likely be running it with U-codes, the thing I always have trouble getting over is the rear shackle angle. It seems like every rsk I see regardless of make is the shackle angle is straight up and down or slightly raked towards the front.
I am no suspension specialist by any means but I have always been under the impression that the shackle is supposed to be angled towards the rear.
With my limited fabrication skills I have often looked at the rear hanger and wondered if I could modifiy it in such a way to move the hanger foward some, cut the ears off, weld some flat plate on it in such a way to move the ears foward slightly and weld the ears back on.
I then ran across an old thread that mentioned SKY has already come up with this and that they sell the hanger individually.
Since I dont see many threads regarding the rear shackle angle, I am looking to hear from anyone running the SKY modified rear hangers and if it would be worth modifiying or buying these hangers??
I would be interested in this answer. I emailed sky with a similar question, no response, if I understand it correctly, about the springs appearing to be pigeon toed, mainly because the front seems to be wider than the rear.
The rear front spring hanger relocation will get the shackle angle correct for SD springs. This is the way it should be done and is supplied with our RS kit.
Discussion Starter · #4 ·
After some more research I'm thinking that building my own rear hangers is going to be the best route. Plan is a 2.5/3.5 PMF rsk with U codes and custom rear hangers.
Gonna cut the ears off the stock hangers leaving a flat surface to weld on some new hangers using something like this...
Discussion Starter · #6 ·
They do look nice, but at approximately $120 I'm sure I could make mine cheaper. With just the pmf kit and no modified hangers im sure that the rear shackle angle would be way off. With the soft U codes I'm not sure that Sky's 3/4 offset hanger would be enough to compensate for the possibly slight inverted arc.
With my pmf kit the rear shackles are made offset on each side so you don't need new hangers.
Discussion Starter · #8 ·
I'm interested to see how it rides with the u codes and the pmf kit. If it rides well without the hangers I might just skip modifying the hangers. Really curious though if the rear hangers would help the ride any....
1 - 8 of 8 Posts
