1 - 5 of 5 Posts
· Registered
If I wanted to put a Dana 60 and a sterling 10.5 in a 95-97 F250, and have four link air ride suspension in both the front and rear, what options are out there as far as companies that could help me with brackets? I'd prefer weld on brackets for the axles. Thanks.
· Premium Member
1995 Ford F-350 7.3 PSD
· Premium Member
This will help for the future, and so others can know what kind of amazing truck you have
You should put ALL the truck's details & history (as much as you know) into your signature so it shows with each post, as this page explains:
1983 Ford Bronco Diagrams picture | SuperMotors.net
Phone apps don't always show signatures, so you may need to switch to a real browser in desktop mode on your phone, or just use a desktop/laptop computer. Put your location (nearest city) in your profile & upload an avatar of the truck. The more pics you post (NOT in your sig) of the truck, engine, wiring, labels, & undercarriage, the more likely we can help you. Not all its details are relevant to these issues, but you don't necessarily know which ones are relevant, so just put everything in now.
· Premium Member
You can also try this website Sky's Off Road Design
sorry for kind of spamming messages. my mind is running super fast right now
· Registered
BlakeJ-
I have a 97 eclb and I just got done putting a 4 link rear suspension along with a new frame I spliced in from the cab back. First "build" I have ever done.
I bought the 4 link kit here: HEAVY DUTY PARALLEL 4 LINK KIT
I used dominator 2600 airbags with fittings to accept schrader valves for now until I convert the ac compressor to an air compressor.
Metals depot had the steel
1/4 inch plate for boxing in frame and making plate on outside of frame to mount the 3x6 tube to
3"x6"x1/4" rectangle tube to have enough spacing for the airbags on axle and room for mounts
2"x5"x1/4" rectangle tube for a cross member
I had to make tabs for the stock shock mounts on the axle but was able to use the existing brackets on the frame.
The whole thing was welded with 7010 rod and 7018 for the brackets for the 4 link.
The front comes next im not sure if i want to keep the dana 50 but do leaf spring delete kit or do a full on super duty dana 60 from late 6.0 era.
Wood Road surface Rectangle Composite material Tints and shades
Tire Wheel Automotive tire Tread Plant
Tire Wheel Automotive tire Tread Synthetic rubber
Automotive tire Road surface Wood Asphalt Motor vehicle
Rectangle Handwriting Font Line Art
Handwriting Font Rectangle Parallel Plan
1 - 5 of 5 Posts
