1 - 2 of 2 Posts
CSAR Bish
Ive came to the conclution that I need to convert my 2wd Dually to a 4x4.. Im well aware of what it entitles and what I will need to do the conversion.. Whats Im comming to ask is, Im having a hard time trying to figure out if I should go with leafs in the front or runs coils upfront and just use my factory coils?
To throw a wrench into the mix my truck is currently lowerd 3"/5", Im wanting to try and keep this height, this is why Im looking at running the coils, but on the leaf side I could run it SUA.. What would work and is this possible?
well if you dont mind swapping the rear axle either, you could go with the 05+ axles, the coils ride so much better than leafs. You will get a much tighter turning radius too
As for keeping the drop that low, I cant answer that. theres nothing better than a slammed 2wd dually
1 - 2 of 2 Posts
