1 - 3 of 3 Posts
Stroke it B!tch
Oasis Report please.
1ftww31p15ea09676
Thank you
Matt
:pullover:
Stroke it B!tch
Discussion Starter #2
can anyone help?
Here you go.....
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 1 1F05 030306 * 8A616 * E23 42 1090
AWS Claim Key: 68078 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:09-SEP-2004 Doc #:86701601
Cust Comments: C S WHILE TOWING 3 QUADS UP A SLIGHT HILL FAN CLUTCH WOULD NOT KICK IN,AFTER GOING DOWNHILL FAN FINALLY KICKED IN
Tech Comments: 1 PERFORM EEC TEST NO CODES USE WDS TO OPERATE FAN CLUTCH REFER TO PINPOINT TEST ALT IN PCED FAN CLUTCH OPERATES
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 1 1F05 030306 4C3Z 8A616 AA G29 42 1526
AWS Claim Key: 73313 Trx Code: 1 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2004 Doc #:86883701
Cust Comments: C S FAN WOULD NOT KICK IN AND VEH STARTED GETTING VERY HOT AGAIN,(G29)
Tech Comments: ROAD TEST VEHICLE FOUND THAT FAN CLUTCH DOES NOT ENGAGE INTERMITTANTLY R&I RADIATOR AND REPLACE FAN CLUTCH RETEST FAULT DOES NOT OCCUR AT THIS TIME
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 7 2H02 030008 3C3Z 6F089 AA N12 42 9320
AWS Claim Key: 575864 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2005 Doc #:97615801
Cust Comments: C S ON INITIAL START UP VEH ENG MAKES A GRUMBLING NOISE WHEN ACCELLING THEN DECELARATING(N12)
Tech Comments: PERFORM 6.0ENG PERFORMANCE DIAG PERFORM APPLICABLE TESTS ON SHEET(ATTACHED).COULD NOT DUPLICATE EXACT NOISE AS 1
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 11 7K11 130101 5C3Z 10849 GA G31 42 15173
AWS Claim Key: 1407328 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2005 Doc #:04478001
Cust Comments: CUSTOMER STATES VEH IS HAETING UP AGAIN, WHEM PULLING,AND WHILE DRIVING,ANF FAN IS CONSTANTLY KICKING ON(C20) SEE RO #872653 AND 868837, TECH 5767
Tech Comments: FAILED INSTRUMENT CLUSTER. ROAD TEST VEHICLE, TEMP GAUGE READS SLIGHTLY HIGH. PERFORM EEC TEST AND COOLING SYSTEM TEST. NO CONCERNS FOUND. REFER TO TSB 05 01 02, REPLACE INTRUMENT CLUSTER AND RETEST. CONCERN NO LONGER PRESENT. FAN CLUTCH OPERATION IS NORMAL FOR CONDITIONS VEHICLE IS OPERATED UNDER.
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 13 2G05 031405 * RECAL * D50 04 15869
AWS Claim Key: 1988620 Trx Code: E84 Labor Hrs: 4
Dlr Cd-Sub Cd: 20337 - * Name: HOLMES TUTTLE FORD, LINCOLN-MERCURY Ph: 520-2923600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:19-SEP-2005 Doc #:08168901
Cust Comments: BASE C SENGINE OR TRANS PULSATES UNDER A LOAD 50 55MPH D50
Tech Comments: PERF DI DIAG.DTC P0148 PRESENT.FUELING ERROR DTC.MAY ITT FUEL PRESSURE GOOD,ICP NORMAL,INJECTOR BUZZ TEST PASS, KOEO PASS,KOER PASS,REC PCM REFLASH PER PP TEST.ROAD TEST VEHCILE TO SEE IF P0 REFLASHED PCM AND ROAD TESTED.P0148 NOT PRESENT. RECAL CC 04 VERIFY 60
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 15 1H03 030008 5C3Z 9F452 AA D50 42 18069
AWS Claim Key: 2431534 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 20337 - * Name: HOLMES TUTTLE FORD, LINCOLN-MERCURY Ph: 520-2923600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:10919201
Cust Comments: BASE C S ENGINE OR TRANS SUGES VIBRATES CYCLICLY WHEN UNDER LOAD AT FREEWAY SPEEDS CONTINUED DIAG PCM POSS NEEDED PER LAST VISIT DIAG D50
Tech Comments: PERF DI PERF TESTS.NO DTC,S PRESENT.MONITOR RECORD EBPA, EGRVP,MAP.EBPA AT 13.42,EGRVP AT .89 HIGH.EGR STUCK OPEN. PERF POWER BALANCE.POWEWR BALANCE PASS.REC EGR VALVE PCM,TCM,FICM REFLASH REFLASHED PCM,TCM,FICM.REPLACED EGR VALVE.ROAD TESTED VEHCILE,VEHICLE OP NORMAL AT THIS TIME.CUSTOMER TO DRIVE VEHICLE AND ADVISE.MAY NEED TO BRING BACK WITH TRAILER ATTACHED.
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 15 5H02 040102 EOTZ 5A313 B N24 07 18576
AWS Claim Key: 2704935 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2005 Doc #:11684702
Cust Comments: DRONING VIBRATION AT 65 MPH WITH TRAILER CONNECTED. DRONING CYCLES ON OFF EVERY 30 SECONDS. DUPLICATED BY
Tech Comments: DRIVE LINE ANGLE CAUSING SHIMMY WHEN LOADED PETE C. ROAD TESTED AND DUPLICATED DRONING WITH TRAILER. CHECHED DRIVE LINE RUNOUT.OK CHECKED DRIVE LINE ANGLES SHIMMED REAR END TO CORRECT ANGLES.CUSTOMER TO ATTATCH TRAILER FOR ROAD TEST.
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 37 * * * * * * * 57702
AWS Claim Key: 8613271 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2007 Doc #:53580203
Cust Comments: RECALL 59B01
Tech Comments: RECALL 59B01. ROAD TEST AS PER RECALL 59B01.
AWS Claim Key: 8613272 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2007 Doc #:53580202
Cust Comments: RECALL 05E15
Tech Comments: RECALL 05E15. INSTALLED EBP SENSOR AND REPROGRAMED MODULES.
AWS Claim Key: 8613273 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2007 Doc #:53580201
Cust Comments: RECALL 05B32
Tech Comments: RECALL 05B32. INSTALLED LABEL AND ADJUSTED COOLANT LEVEL.
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 44 1A02 030102 * 6051 * E41 42 70104
AWS Claim Key: 9585639 Trx Code: E72 Labor Hrs: 18.6
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2008 Doc #:65161201
Cust Comments: CUSTOMER STATES COOLANT HAS BE ADDED AND WHITE SMOKE SEEN COMING OUT OF EXAUST(ADV)
Tech Comments: VERIFIED CONCERN. REFERRED TO TSB 08 03 07. TRACED TO FAILED OIL COOLER AND EGR COOLER. REPLACED EGR COOLER OIL COOLER. MOTOR WAS HYDRO LOCKED DUE TO COOLANT LEAK. REMOVED GLOW PLUGS TO CLEAR MOTOR. VEHICLE WAS A CRANK NO START. NO ICP. AIR TESTED LEAKING AT REAR OF ENGINE. REMOVED TURBO AGAIN TO ACCESS IPR. IPR COATED WITH DEBRIS. REPLACED PUMP AND IPR. NO HI PSI OIL LEAKS. ROAD TESTED. NO CONC
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 44 1B02 030404 4C3Z 9C166 AA L65 42 70358
AWS Claim Key: 9598860 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2008 Doc #:65900701
Cust Comments: CUSTOMER STATES OIL IS LEAKING FROM UNDER ENGINE AREA
Tech Comments: VERIFIED CONCERN TRACED TO OIL FILTER HOUSING HAS A PINHOLE IN HOUSING. REPLACED HOUSING. TRANSFERED ALL PARTS OVER. ROAD TESTED AND STEAM CLEANED ENGINE. NO LEAKS USE M TIME TO REPLACE NO OP.
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 46 2A01 031202 6C3Z 6C640 C D42 42 71609
AWS Claim Key: 9853207 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2008 Doc #:69335902
Cust Comments: CUSTOMER STATES VEH LACCKS POWER ON ACCELL
Tech Comments: REINSPECTED VEHICLE AFTER WIRING REPAIR NO ISSUES NOTED 1
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 46 2D01 180101 5C3Z 12B637 BA D02 42 71609
AWS Claim Key: 9853208 Trx Code: E72 Labor Hrs: 9.7
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2008 Doc #:69335901
Cust Comments: CUSTOMER STATES VEH WILL CRANK BUT NOT START(ADV)
Tech Comments: PERFORMED DIAG FOUND MULTIPLE CODES, FORCED POWER LIMITATION AND FORCED IDLE, INSPECTED INDIVIDUAL ITEMS, FOUND NO PEDAL ISSUES NO COMPONENT ISSUES REMOVED AND INSPECTED HARNESS FOUND FICM HARNESS C REMOVED FRONT ENGINE, TURBO AND REMOVED AND REPLACED ENGINE HARNESS AND FICM HARNESS, RE ASSEMBLED REPARED BODY CONNECTOR AT PCM RETESTED NO FURTHER IOSSUES WITH HARNESS AT THIS TIME VEHICLE RUNS AND D
1FTWW31P15EA09676 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUL-2004 27-AUG-2004 171205 USA 49 2E03 0304XX 5C3Z 9C968 CA D03 D8 79010
AWS Claim Key: 10326852 Trx Code: E72 Labor Hrs: 13.3
Dlr Cd-Sub Cd: 20402 - * Name: JIM CLICK FORD, LINCOLN-MERCURY Ph: 520-7472000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:27-AUG-2008 Doc #:76513701
Cust Comments: CUSTOMER STATES SLOW STARTING REPLACED BOTH BATTERIES,STILL SLOW STARTING NOW WILL NOT START(ADV)
Tech Comments: VERIFIED CONCERN. ICP LEAKING AT FITTING AND IPR FAILED. REPLACED STC FITTING AS PER TSB AND REPLACED IPR. ROAD TEST NO CONCERNS PRESENT
1 - 3 of 3 Posts
