1 - 5 of 5 Posts
Hey guys I'm at work and need to know if my truck has had the STC fitting upgraded and the dummy plugs upgraded. If not I'm going to get them ordered. Can somebody run this for me please?
2005 F250
VIN 1FTSW21P95ED09300
Thanks
OASIS RESULT: 1FTSW21P95ED09300
USA: EN-US
05-JULY-2011 / 19:53:44 / FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2005 F-SERIES BODY STYLE: F-250 CREW CAB 4X4 ENGINE: 6.0L DIESEL DI V8
TRANSMISSION: TORQSHIFT AXLE CODE: 3L ENGINE CALIBRATION
PAINT COLOR: EBONY WB C/C-W/B RADIO: AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT: 10,000 LB. GVW
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 8X20" FORGED POLISH ALUM WHEEL FRONT TIRE: 275/65R 20E A/T BSW TIRE
NO WARNING MESSAGES FOUND FOR THIS VIN
ACCURATE REPAIR NOTIFICATIONS
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
DON'T REPLACE A FICM ASSEMBLY WITHOUT FIRST REFERENCING 10-12-06
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 14-MAY-2005 BUILD DATE: 08-APRIL-2005 SALE MILEAGE: 00374
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
Standard Claims List For Model Year 2005
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 10 * * * * * * * 10372
AWS Claim Key: 3566455 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03261 - * Name: TERRY HOLMES FORD LINCOLN MERCURY Ph: 478-9229131 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:02680703
Cust Comments: RECALL, 05B32
Tech Comments: RECALL INSTALL NEW FILL LABEL ON DEAGS BOTTLE
AWS Claim Key: 3566454 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03261 - * Name: TERRY HOLMES FORD LINCOLN MERCURY Ph: 478-9229131 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:02680704
Cust Comments: RECALL 05B35
Tech Comments: RECALL INSTALL NEW COMPUTER CALIBRATION
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 16 6L01 011201 * 2804320 * N33 33 17527
AWS Claim Key: 5819391 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03261 - * Name: TERRY HOLMES FORD LINCOLN MERCURY Ph: 478-9229131 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2006 Doc #:03630302
Cust Comments: CUST STATES WHEN DRIVING DOWN RD WHEN DEACCELERATING TRK MAKES RATTLING NOISE SOUNDS LIKE COMING THREW DASH
Tech Comments: TECH FOUND CLIP BEHIND DASH RATTLING,REMOVED DASH TO TAKE CLIP OUT INSTALL NUT AND BOLT NO MORE RATTLE 04470A .70
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 30 6Q05 011901 6C3Z 17C882 A B66 34 34874
AWS Claim Key: 8985028 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03261 - * Name: TERRY HOLMES FORD LINCOLN MERCURY Ph: 478-9229131 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2007 Doc #:05652301
Cust Comments: CUST STATES FRONT BUMPER WARPED HAS WAVES
Tech Comments: TSB 05 25 11 PAAHX OK TO REPAIR PER FORD PERFORMED TSB TO REPAIR BUMPER VERIFIED REPAIR
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 30 6N07 010801 6C3Z 8200 DA B65 34 34874
AWS Claim Key: 8976835 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03261 - * Name: TERRY HOLMES FORD LINCOLN MERCURY Ph: 478-9229131 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2007 Doc #:05652302
Cust Comments: CUST STATES TOP OF GRILL WARPED
Tech Comments: DEFECT IN GRILL REPLACED GRILL PER FORD PAA3W
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 50 2E03 030402 4C3Z 9E527 BRM D42 42 62500
AWS Claim Key: 11075446 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 08778 - * Name: PEACH COUNTY FORD, INC. Ph: 478-9564007 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2009 Doc #:01621302
Cust Comments: CUSTOMER STATES EXCESSIVE SMOKE COMING FROM EXHAUST PIPE HARD TO START
Tech Comments: FOUDN NO 3 AND 6 INJ DEFECTIVE EGR STICKING VERIFIED CODES P0404,P0403,P0269,AND P0278. TEST DROVE TRUCK SEVERAL TIME FELT SKIP AT TIMES. USED POWER BALANCER AND SAW 3 AND 6 INJ SKIPPING AT TIMES. PERFORMED INJ TEST CYLS BALA NCE TEST. WIGGLE TEST HARNESS OK. REMOVED BOTH VALVE COVERS AND REPLACED INJS.ROADTESTED AND CORRECTED SKIP BUT EGR TEST FAILED, SLOW TO OPEN. RR EGR REPLACED RETESTED OK
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 52 2E03 030402 4C3Z 9E527 BRM D03 42 65454
AWS Claim Key: 11104151 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 08778 - * Name: PEACH COUNTY FORD, INC. Ph: 478-9564007 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2009 Doc #:01675402
Cust Comments: ENGINE RUNS ROUGH COLD
Tech Comments: VERIFIED CONCERN FOUND 1,5,6,7 INJS SKIPPING ON COLD START PERFORMED TAB 09 07 11 AND REPROGRAMMED PCM,TCM, AND FICM LET VEHICLE SIT OVERNIGHT AND STILL SKIPPED ON FOUR CYLS PERFORMED INJ TEST ALL PASSED. REPLACED ALL FOUR INJS AND NO SKIPPING ON COLD START IN MORNING
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 55 1B03 030204 3C3Z 6A642 CA L85 55 69000
AWS Claim Key: 11273435 Trx Code: E72 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 08778 - * Name: PEACH COUNTY FORD, INC. Ph: 478-9564007 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2009 Doc #:01808202
Cust Comments: C S THAT THE VEHICLE IS BLOWING WHITE SMOKE....
Tech Comments: EGR COOLER AND EGR VALVE BAD.... VERIFY CONCERN ON TEST DRIVE...RUNS ROUGH AND BLOWING WHITE SMOKE(RETRIEVED CODES)...P0611.P0404,P0405. REMOVED EGR VALVE, FOUND WATER ON VALVE. PERFORMED TSB 09 08 3. FOUND DEGAS BOTTLE OK, CAP OK, BUT WILL NOT HOLD VACCUM. REMOVED EGR COOLER, FAILED BUBBLE TEST...GOT PRIOR APPROVAL CODE PAASX...R&R EGR COOLER, OIL COOLER KIT, FLUSHED COOLING
1FTSW21P95ED09300 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-APR-2005 14-MAY-2005 121004 USA 55 2E03 031403 4C3Z 12B599 ABRM D42 42 69000
AWS Claim Key: 11271039 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08778 - * Name: PEACH COUNTY FORD, INC. Ph: 478-9564007 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2009 Doc #:01808203
Cust Comments: C S THAT THE VEHICLE IS RUNNING ROUGH....
Tech Comments: ON TEST DRIVE FICM VOLTAGE LOW AT 35VOLTS....PERFORMED TSB 08 26 3...PERFORMED VOLTAGE IN TEST,EOT TEST...ALL OK... VOLTAGE OUT OF THE FICM PROBLEM. R&R FICM PER TSB, TEST DROVE AGAIN AND ALL OK....
FORD POWER
How do you get this history?
Thanks so much. Yeah wudda history.
1 - 5 of 5 Posts
