1 - 4 of 4 Posts
1FTWW33P36ED55842
Thanks
PSA
i could be wrong but I believe they don't do OASIS reports here anymore
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4L ENGINE CALIBRATION
PAINT COLOR
SILVER MET WATERBORNE RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
13,000 LB. GVW
AXLE RATIO
4.30 FINAL DRIVE RATIO WHEEL SIZE
17 X 6.5 ALUM - MCHND FINISH FRONT TIRE
LT245/75/R17E A/T OWL
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/02/2006 BUILD DATE
04/12/2006 SALE MILEAGE
00006 New Vehicle Base Warranty
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/03/2009
DEALER: Raceway Ford
WARRANTY CLAIM NUMBER: 616874 ODOMETER: 057391M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 090803A 55 PLUGGED/RESTRICTED
3C3Z 9P458AA KIT - VLV EGR 001 090803B
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 090803F
3C3Z 6A642CA COOLER CRANKCASE OI 001 090803G
3C3Z 6C683AB FLTER-ENG OIL 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
VC 9 002
3C3Z 9A564A TUBE ASSY-FUEL RET 001
6C3Z 6C640A CONNECTION A/C DUCT 001
6C2Z 6K786AA CLAMP AIR COOLING 002
VC 7B 002
CHECKED FOR CUSTOMER CONCERN,VERIFIED CONCERN,TRUCK HAS CHECK ENGINE LIGHT O N AND HAS WHITE SMOKE,AND LOW ON COOLANT ALSO,PERFORMED VISUAL INSPECTION OK,CHECKED OIL,FUEL ALSO GOOD,PERFORMED KOEO TEST,HAD CODE FOR EGR SYSTEM, P O404,AND PERFORMED AIR MANAGMENT TEST ,FAILED,REMOVED EGR VALVE FOUND CLOG GLED AND ALSO HAS COOLANT IN INTAKE MANFOILD,FOLLOWED TSB -09-8-3,PRESSURE
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWW33P36ED55842 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-APR-2006 02-MAY-2006 171105 USA 15 7B02 140201 6C3Z 10346 DA C25 63 22914
AWS Claim Key: 4009365 Trx Code: E83 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 05395 - * Name: HEMBORG FORD Ph: 951-7376151 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2007 Doc #:09802951
Cust Comments: BATT LIGHT COMING ON WHILE DRIVING ALL GAUGES DROP ALL THE WAY DOWN
Tech Comments: INSP BATT LIGHT ALTERN TST FAILED ONLY 12.83 VOLTS REPLACED ALT RETSTS OK 14.12
1FTWW33P36ED55842 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-APR-2006 02-MAY-2006 171105 USA 19 2G05 031405 * RECALEM * D50 82 25241
AWS Claim Key: 4910268 Trx Code: S07 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 05395 - * Name: HEMBORG FORD Ph: 951-7376151 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2007 Doc #:00884851
Cust Comments: WHISTLE NOIE HEARD ON ACCEL, FROM TURBO AREA
Tech Comments: IDS DIESEL ENG DIAG KOEO TEST CODE PASS KOER TEST PASS TURBO BOOST TEST PASS EGR TEST PASS RPROGRAM MODULES AND RETSET CODE PASS PID MONITOR TST AND ROAD TEST 11 MILES FULE CONSUMPTION TST GETTING 1306 MPG ON HWY 65
1FTWW33P36ED55842 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-APR-2006 02-MAY-2006 171105 USA 26 2A01 031202 6C3Z 6C646 BA N17 D1 28989
AWS Claim Key: 6294919 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 05395 - * Name: HEMBORG FORD Ph: 951-7376151 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-MAY-2008 Doc #:02296951
Cust Comments: WHISTLE TYPE NOISE FROM ENGINE AREA
Tech Comments: IDS SYSTEM TST CODE PASS KOER TEST CODE PASS TURBO BOOST TEST LOW 20PSI PP TST AND LEAK TEST REPLACED AIR TURBE LEAKING TO TURBO RETET CODE PASS 24.6 PSI
1FTWW33P36ED55842 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-APR-2006 02-MAY-2006 171105 USA 43 1B03 030204 3C3Z 6A642 CA E29 55 57391
AWS Claim Key: 8734893 Trx Code: E72 Labor Hrs: 10.5
Dlr Cd-Sub Cd: 05485 - * Name: RACEWAY FORD Ph: 909-7841000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2009 Doc #:616874A
Cust Comments: CK CUSTOMER STATES THAT CHECK ENGINE LIGHT COME ON INTERMITANTLY ADVISE
Tech Comments: CHECKED FOR CUSTOMER CONCERN,VERIFIED CONCERN,TRUCK HAS CHECK ENGINE LIGHT ON AND HAS WHITE SMOKE,AND LOW ON COOLANT ALSO,PERFORMED VISUAL INSPECTION OK,CHECKED OIL,FUEL ALSO GOOD,PERFORMED KOEO TEST,HAD CODE FOR EGR SYSTEM, PO404,AND PERFORMED AIR MANAGMENT TEST ,FAILED,REMOVED EGR VALVE FOUND CLOGGLED AND ALSO HAS COOLANT IN INTAKE MANFOILD,FOLLOWED TSB 09 8 3,PRESSURE
| On-line 1878
1 - 4 of 4 Posts
