1 - 1 of 1 Posts
I have been chasing a new drive line mild vibration when I let off the gas , briefly before the truck starts to slow down. I took both rear shafts out . I see nothing wrong with them. I am taking them to local Drive shaft shop for new joints and balancing and carrier bearing anyhow.
I grabbed the rear output companion flange on the NV271 and I can shake the companion flange on the shaft. The shaft is tight but the flange is a little loose on the shaft. I am thinking is this ok ?? Can I tighten the big nut ??
Thanks in advance
1 - 1 of 1 Posts
