1 - 15 of 15 Posts
Howdy yall my truck just started doing this and it's not wanting to start, but number 2 relay under hood is clicking really fast and non stop, I do have a check engine light on and no flow plug light, I have checked all fuses and even changed out the relays still doing the same, help please, hope everyone having a bless day
Have your batteries checked and independent from one another. The symptoms usually indicate a voltage problem. The only time I've seen it personally is when one of my brother-in-law's batteries went bad when he tried to start the truck. If not that, check all battery cables and ends for cleanliness and tightness. Cheers!
Well brand new batteries and new battery cables, my wait to start like is flashing now after I put a new glow plug relay on and truck will start then dies, over and over, right now I'm changing the wire hardness so hope it's the problem, if not i heard that my ecm could want out
The WTS light has nothing to do with the glow plug relay, it is just a idiot light.
Your symptoms are a bad or low voltage with the batteries. It can also be a bad connection or a bad ground
Sent from my SM-J737V using Tapatalk
Are there any mods to your truck (chip, tuner etc.)? You might want to take a look at the PCM connection and maybe the IDM and IDM connection. Cheers!
And the problem was …..??? Cheers!
I guess someone can't take the time to write a complete sentence (with punctuation) and describe what part of the harness was affected (and maybe why if known). Cheers!
1 - 15 of 15 Posts
