Hello, I have a ‘06 6.0, blew the trans last weekend and got the new one put in earlier this week all went well no issues got everything good to go went to start the truck and it’s a crank no start, after digging into it I was able to figure out that it’s not building enough high pressure oil, thinking it’s just a coincidence that it happened right after the trans install but figured I’d add that just in case, after cranking for 45 seconds to a minute it will build the 500 psi it needs run for 2-3 seconds then die, so I did some digging and replaced Ipr and icp both with new pigtails and I put 150 psi of shop air through the system with no notable leaks, Ipr duty cycle show 14% ignition on and 66-85% cranking, stc fitting has been updated, I’m stumped as to how something like this could happen over night, truck ran fine after the trans blew, if anyone has any input it would be greatly appreciated
