1 - 6 of 6 Posts
Im stroke-less
Ok I put the edge Cts with the edge tow tune while I'm waiting on my php tunes. I was empty running about 70ish mph and the oil temps was running about 195-205 depending on the grade. My oil is almost due for a change. Are these temps high or good? Seems a little high for me. Trans was running around 160. Thanks for any help in advance.
Good!! No worries.
Im stroke-less
What would be pushing the limits on the oil and trans temperatures? Just so ill know when to worry.
engine oil would like to be below 225.
Trans oil below 200*... ideal would be 150-180. 220* is when you need to pull over and shut her down
Im stroke-less
Ah thanks fer the info.
I would pull over and let it idle, keeping the fluid moving. Just my $.02
1 - 6 of 6 Posts
