Status
Not open for further replies.
1 - 18 of 18 Posts
03 F350 7.3L
What EGTs do you guys see at 45mph on flat ground, unlaoded and at 55mph on flat ground unloaded?
Air temp 50 degrees.
Whats normal EGTs unloaded?
03 F350 7.3L
I see 600 at 45mph and 500 at 55mph.
Like the others said, around 500-600 would be normal at those speeds.
I would have to check later but i think mine are probably around 600 if the motor is lugging in OD, maybe 400 if its running higher RPM out of OD. (that speed is around where my truck shifts)
<<< THE GAUGE WHORE...
Altitude will effect that more then ambient air temps...
Normal for a truck with stock tires, and such will be between 500-700*.
Sounds completely normal for a pre-turbo pyro.
Compared to everyone else, mine are rather low. At 55 on flat ground I'm between 400-500
Are you running a pre-turbo pyro or post turbo?
I'd be really surprised if you were down at 400*, thats really too low for proper combustion and power.
I can agree with that, and now that I think of it, it is probably closer to 500. but that is also with the truck in 3rd gear and almost no throttle input to keep it moving at that speed. 55 is not really a comfortable speed for my truck, too slow to really spool the turbo in OD, and moves effortlessly in 3rd. Does that make any sense?
03 F350 7.3L
Discussion Starter #9
I saw 950 today climbing a hill. That just seems really high for an unloaded not towing anything temp. I am at 3,000ft elevation, i think i would hit 1250 easily pulling my Jeep or my Muscle car, unless i am just lost on how the engine reacts pulling temp wise.
Pulling my RV...
I would say that is still fine. The temps might climb quick at first, but unless you have a chip dumping tons of fuel with no safeties, they do stop rising once they get up above 1000. I understand your concern, but I think you are over thinking it.
Besides, I think it was CSIPSD who mentioned that its not so much about momentary temps reaching the suggested peak of 1250, its the time they spend there. A quick flash of a few minutes will not harm anything, but a drive for hours at 1100 with some peaks at 1250 or more will cause damage. Its all about the engine absorbing the heat, or blowing it out the exhaust.
Someone correct me if Im wrong
before my truck was Intercooled I would run 1200 consistently at 65-70 with no issues
And what does it run now? Just to see what a difference it makes.
900-100 . The ic helped alot. But I have a different turbo to
About 600-700
03 F350 7.3L
Discussion Starter #16
I've noticed lower EGTs on flat ground with warmer air temps but in Race tune on my chip.
03 F350 7.3L
Discussion Starter #17
double post
1 - 18 of 18 Posts
Status
