1 - 11 of 11 Posts
i have all lights working other then the running lights, on a 4 way plug for my boat.
also i had to replace the 4 way plug cuz the first one got broken, the orginal boat plug has 5wires white green yellow and 2 black? and the new plug only has 4 white-ground green-signal yellow-signal and brown-tail lights, what do i do with the 2 black's hook them together & then to the brown?
any input is thanked.
Discussion Starter #2
UPDATE
its for sure something with my truck, hooked it up to my dad's little 4runner, twisted all the wires on and bam all lights are working. is their a fuse or something for the trailer running lights? ide look myself but my truck is without the owners manual.
All done now
Yes, under the hood. like 7.5 amps fuses or something like that.
All done now
PSN Pretender
Is there power to fuse #4?
Check power to the trailer harness(truck side), then check it at the connector about 18'' before that, should be clipped to the frame next to spare tire.
Discussion Starter #9
:doh: conector up by the tire was loose, snugged it up wiggled the trailer plug and wa-law they all work. thank you very much for the help.
Keep er shinny side up!
since it was loose i'd take it back apart when you get a shot at it, clean it up and put the die electric grease to it and put it back together.
Dave
im gona redo the wires/plug from the conection back, my plug is tmpermental. you have to put it in like 3/4 of the way and kinda kink it to the side for the runner's to work
1 - 11 of 11 Posts
