1 - 4 of 4 Posts
I just got an sct tuner to do custom tunes on my truck and when i try to get the code it says "no strategy code". Im have the edge juice with attitude (the gray one) and i was planning on leaving that for gauges but would that have an effect on it? and could someone tell me how to take it off my truck? it came with the truck and i have no clue where the connections go.
Thanks
Matt
Just above the drivers side wheel well is where the main harness plugs in. There is also a 2 wire cable that goes over to the passenger side for I believe its for the MAF sensor. If you have the EGT sensor, its the two wires that are bolted together and run down to your exhaust manifold.
Your better off getting it out before you install the SCT tunes.
What does the big plug plug into? I can't seem to find a spot for it
Discussion Starter · #4 ·
i got it figured it out now. i just never took the time to look where things went because i was on lunch break
1 - 4 of 4 Posts
