1 - 1 of 1 Posts
2008 6.4 with 148k, zf6 trans, dashdaq with spartan tunes, dpf delete 5” exhaust, I bought the truck cheap because I bought it not running, previous owner said he was driving down the road and stared losing power and blowing a lot of black smoke, he limped it home and put an air filter in it and never got it running.
Since i got the truck I’ve don an oil change, Changed fuel filters (they were black as the tires), cam sensor, crank sensor, fuel rail pressure sensor, oil pressure switch, oil temp sensor, EBP sensor, check fuel bowl for shavings and it’s clean, I did an egr delete, new batteries, did buzz test on injectors, only codes I get are an intermittent cam sensor, and then glow plugs 5,7,and 8.. I’ve tried multiple ways to bleed the fuel system. I get pure fuel out the shearer valve on fuel cooler. Can’t get it to fire even off of either. I’m getting good fuel pressure and no codes so I’m at a loss of what my next move should be. Any ideas would be greatly appreciated
1 - 1 of 1 Posts
