1 - 3 of 3 Posts
I have a 04 f350 6.0 crew cab dually lariat le. In the morning it starts up an runs like it s suppose to. As soon as the engine warms up an I cut it off it will not start back up until it cools off. As long I I don't cut it off it will run all day. Any body had this happen.
You have a leak in the high pressure oil system. 9 times out of 10 it's the stc fitting on the back of your high pressure oil pump. But there are a few other things it could be as in a bad o-ring on one of your injectors, or bad o-ring on one of your dummy plugs
Fixing Broken Stuff
:whs:
1 - 3 of 3 Posts
