1 - 9 of 9 Posts
I have an 04 6.0 and i was driving today I stopped at a stop light and went to accelerate and it was like i had no power it was bogging down and blowing smoke everywhere. HELP PLEASE, I had it towed to the local ford dealership but they are closed until Monday:confused:
Here for the Ride!
Sounds like the veins in your turbo aint working
I don't think it would start if the egr was stuck. Deffinetly would idle and run like crap. You could always pull the valve and check it out tho and clean it up. Sounds like the turbo tho.
"resident smarty pants"
Black smoke? If so, definitely check the EGR valve.
i'd pull the EGR and check it out definitely. had the same trouble with mine. ran but would pour black smoke and didn't have enough power to cross the road sometimes
Try the cheapest (free) fix first. Pull the EGR valve using a length of strong wire and a lifting lever. Carefully clean it. Do not get solvent in the holes on the under side. Carefully push it open with a big screwdriver. Lube it a little with 2-stroke outboard motor oil. When you are done, that EGR valve should shine, open and close easily and seat completely. Good luck.
1 - 9 of 9 Posts
