Can anyone help me? I know there's quite a bit of yall who know a lot. I need some advice on what I should do. I have determined that the up pipe has come undone from turbo and the bolts are missing.
Well there is a small oil leak that I believe is comming from oil return line Gasket??? But Its only a few weeks old. But my exaust leak is very bad. You can hear it in can with radio on loud. I think I blew out an up pipe. And that's why? I don't know till I cAn see it. How bad is dropping the transmission on these trucks? Any tips?Even at that you should still have boost if the down pipe is off, all the pressure is container on the intake side of the turbos? There must be another boot loose or cut somewhere, almost has to be. Unless the turbo is out. Surely someone else will chime in
