1 - 2 of 2 Posts
2004 6.0 150,000 miles truck quit out of nowhere. Took the front cover off and replaced the lpop and front cover because I cracked the front cover and blew the gears into pieces. Still not base oil any ideas on where I should go next?
"resident smarty pants"
There is a whole lot of detail not included in your post!!!
What caused the LPOP to fail in the first place?
Is the regulator free of debris? Were the LPOP gear pieces large or small? Any pieces missing?
Are you just looking at the dash gauge to say whether or not you have low pressure oil pressure, or have you at least checked for flow by cranking w/ the oil filter cap off and assessing the fill rate? Maybe the pressure switch is bad?
Have you put a manual gauge in the oil pressure test port?
1 - 2 of 2 Posts
