1 - 14 of 14 Posts
Cummins Power
This thing is about to piss me off. The axle is out of an 07 and the further I get into it everything is different. I have to machine the outer hubs because there are no 8x200 wheels available. Now the outer hub axle flange bolt pattern is different. Center to center is 4.200 with 12mm bolts and everything else is like 3.800 and 7/16th bolts. Any ideas other than $1200 special made axles?
I'm just about ready to sell out. I have spent so much money for so little fun.
Cummins Power
Something better than stock?
Cummins Power
Discussion Starter · #5 ·
Well I broke a 10.5 axle and if you compare the two in diameter there is no difference. When I busted the one in the 10.5 it took the locker out with it. I don't want to half ass it from the start.
did you get the axle out of an 07 dually?
my buddys 05 F-350 dually had the Dana 80
good luck!
Fat Kids Rule!
kevin i never broke any dana 80 parts in mine, i honestly think ford 80s re better then dodge 80s
Cummins Power
Discussion Starter · #8 ·
Yes it's out of an 07. I'm going to try it and hope it stays together.
Cummins Power
Discussion Starter · #10 ·
Uh... no. I have one on my shop floor with 35 spline axles.
FNG
Cummins Power
Discussion Starter · #12 ·
At least 05 and up 8X200 wheel bolt pattern.
Cummins Power
Discussion Starter · #14 ·
I've already machined the hubs for 8x170 and will run the axles as they are.
1 - 14 of 14 Posts
