1 - 1 of 1 Posts
Premium Member
White 3 in 1 Combo Gauge - Boost, Exhaust Temp, Temp Readings - PreOrder - Ships April 30th
GlowShifts newly released White Face 60mm 3 in 1 Combo Gauge allows you to easily monitor some of the most vital engine readings while allowing you to select from ten backlighting colors designed to match your vehicle’s stock gauges. This unit will allow you to read boost pressure from 0 to 60 PSI, exhaust temperature from 200 to 2200 degrees Fahrenheit as well as a choice of oil, coolant or transmission temperature from 68 to 302 degrees Fahrenheit. Boost pressure, exhaust and temperature sensors are all included. Select from ten bright backlighting colors as well as two color cycling modes including a color fade and color cycle feature. By bringing three meters into one gauge, this allows for a reduction in the amount of space needed for automotive gauges in your vehicle’s interior and at the same time allowing you to observe your engine more readily in one well designed compact unit. Install the included temperature sensor to either your oil, coolant or transmission senders to effortlessly monitor it using the digital temperature readout on the unit itself. Each package also includes a gauge pod to easily mount the unit on your dashboard. Each gauge includes GlowShifts standard one year limited warranty as well as free technical support.
Gauge Ranges:
Boost 0 to 60 PSI
Temperature 68 to 302 F
Exhaust Temperature 200 to 2200 F
Price: $169.99
1 - 1 of 1 Posts
