1 - 7 of 7 Posts
Steel mill smoker
Ok got my ts 6 position from Trey and php tuned on it. Hooked it up last night it worked in only four positions one is no start, so drove to work ran great same thing home, this morning I go to leave and no start take it out clean contacts again of silicone I missed with tooth pick and finger nails and nail polish remover as instructed to, put it back I nothing I any positions so I took it out and am at a loss
use some steal wool and clean the contacets good, but dont take them down to the copper.
Compressed air is the only way to effectively clean the contacts. If you try to use anything mechanical (toothpick, paper, etc.) you can bend the pins in the connector. What may often help is to install/remove the chip from the PCM several times in order to create a wear pattern between the chip and ECM. Obviously, make sure the key is removed from the ignition when attempting this.
Let me know if you have any further problems.
1 - 7 of 7 Posts
