1 - 2 of 2 Posts
I took a shot and bought a 2007 F250 XLT extended cab automatic long bed, Curt gooseneck hitch, Linex. It needed tires and a windshield, which I got the next day. I went with Pirelli Scorpion STRs. The truck has 220,000 miles on it, but if you do the math with the engine hours, you find it has averaged 47.9mph. There's a little dent in the rear bumper, but the rest of the truck is like new. Interior and exterior are nearly pristine. I have 4 gal Rotella T 15w40, Racor PFL2016 oil filter, Prime Guard PDF 9667 fuel filters, and a K & N 57-2546-1 cold air intake on order. I do not know anything about the oil and antifreeze that came in the truck, so I want to have an oil analysis done first and decide on the oil change from that. When I do change the oil, I will install a Fumoto valve and have an oil analysis done every oil change. I also want to pull and clean the EGR, using new O-rings from Ford, and I have a coolant filter system on order from DieselStorm. I'll decide on a coolant flush and change when I look at the first coolant filter after 500 miles. I am not into EGR delete (California smog check), and I don't have much use for a tuner. I buy tires for long wear and fuel mileage, and I do not hot rod around. I may eventually pull a midsize 5th wheel. So, am I on the right track with my plans for this truck? Am I leaving anything out? What fuel mileage should I expect? BTW, I paid $8500 for the truck, KBB $16,100. Sorry I'm so long winded, and thanks for any tips, FirstSixOh, San Diego
1 - 2 of 2 Posts
