1 - 20 of 41 Posts
Hi everyone,
My name is Andrew, and ive got a 2002 f350 7.3 powerstroke, and i need your help. the truck had a terrible idle so i brought it to a diesel shop and than to ford.. the problem is still exactly the same... they have now changed injector #8 & #3, all remaining O-rings, the uvc harnesses, the valve cover gaskets, the ICP and the IDM... sounds exactly the same...
what else could it be..
anything will help ;)
Discussion Starter #2
also... this only happens once the truck gets to operating temperature. does anyone know what else i may have over-looked that could relate to the truck heating up..
runs perfect when shes cold.
THX...
do a compression test. the if it passes your going to have to hook it up to a scanner and get live data feed. with the things that have been replaced there are only a few other things it could be
The mechanic at my local for dealer is having me bring the truck back monday so that he can dig further on his diagnostic, il ask him to check the compression but what would that point to? what part or sensor could be causing these symptoms. he said it could be the IPR but he is confused because of the fact that it only occurs when its at running temp.
anything else i could look at.. I read a thread about "cracked oil pump pickups" but would that cause a consistent misfire?
well if it runs good with the icp unplugged its either the icp or the harness
Is it bad to run the engine with the ICP unplugged. Like can I unplug it at certain points in the diagnostic... Is that bad?
no it wont hurt as long as you don't try to drive with it unplugged
ya unplug the harness from the sensor
just look to see if it is chewed up mabey a squirrel or some other kind of rodent or evem chafing from another part of the motor
the harnesses are cheap like 20 or 30$ no problem that's what this site is for
:psn:
Discussion Starter #15
ok.. so I checked the harness and it didn't look damaged but i changed it anyway... the misfire/rough idle is still there... still the same...
where should i look next...???
Thanks
are you loosing any coolant or getting white smoke when its at full operating temp?
Discussion Starter #17
about three months ago I noticed the coolant was a bit low so I added some but it may have been low from when I purchased the truck. The level looks good now though..
As far as smoke, there is no white smoke. Almost no smoke at all... Although, I live in Canada and on really cold winter mornings the truck will blow white smoke for the first couple of minutes.
well that's normal just making sure you don't have a blown head gasket. the only other thing I can think of is the pick up screens in the tank are clogged up and not getting the right fuel pressure
have you checked or changed the fuel filter?
Discussion Starter #20
I have not investigated it... How should I check or diagnose that, and could that be something that would change based on the temperature of the engine? And corrected by unplugging the ICP?
Thanks a bunch...
I really appreciate you help
1 - 20 of 41 Posts
