1 - 3 of 3 Posts
So I had a previous thread on my truck randomly shutting down finally was able to fix it it was a bad pcm. Installed the new one plugged my ts 6 position on and it doesn't do anything. Wondering if its because of the updated pcm. I bought it brand new from a local diesel performance shop. And if my ts needs to be refreshed any recommendations on where to send it?
Does your truck run without the chip plugged in?
What do you mean by it doesn't do anything?
Did you clean the contacts before installing the chip?
Yes it runs I cleaned everything before the install did everything you're supposed to do when you install them, unplug the battery etc. But when it's plugged in and running when I turn it to high idle it doesn't respond and every other tune that is supposed to be on the chip is like stock tune. It's like the chip is blank.
1 - 3 of 3 Posts
