1 - 5 of 5 Posts
I just installed new hpop everything back together doesnt start,, showing 940 psi from hpop, 34.4 icp and ficm showing 47.5-48 volts.. i dont know what else to check.. ive cranked & cranked on it thinking just air in system ran my batteries down & recharged them twice and still same issue.. Can Anyone help!?!?!!?!
Fixing Broken Stuff
Why did you replace your HPOP?
The 34.4 icphas me confused, where are you getting that from?
Are you getting any codes?
Like lenz says check for sync, you say it has 940 psi ICP, so that enough.
check fuel pressure (at least 50 psi), check your fuel filters and see how they look.
Discussion Starter · #5 ·
tool i had a crank no start issue diagnosed it to the hpop.. got hpop back in and it still wasnt starting.. for the other guys i found loose connection on the ficm.. thanks for the tips!
1 - 5 of 5 Posts
