1 - 20 of 20 Posts
02 F250 / 7.3L / 4X4
I just did an oil change and new fuel filter. This was the first time I changed the fuel filter since I've had the truck. I've had it for about 50k miles. I've noticed that now after the new filter I'm getting white / grey smoke. I still get black smoke with heavy acceleration, just not all the time. And doesn't seem to be as much as it use to. Also I've been getting a puff of grey smoke when the truck starts, use to be black. This morning I got a puff of grey followed by a puff of black when I started it. Feels like I've lost a little bit of power as well. 2002 f250 7.3L with 175,xxx miles. Tunes from Matt at gearhead, afe stage 2, 4" exhaust and pyro, boost and trans gauge.
I've been searching around on here all day and from what I've gathered, might be injector problems. How can I know for sure? I want to upgrade my injectors, just wanted to wait a little bit. Thanks guys, any advise would be appreciated.
Discussion Starter · #2 ·
Bump.
Village Idiot
I try and keep mine changed at 10-12k
Discussion Starter · #6 ·
That's the problem, I didn't change it, my buddy did. I was on call at work. We were finishing up the oil change and I had to leave. It was done when I got back.
Hood Rich
Well, I cant assume his methods, but if you did notice a difference he probably did not drain the bowl prior to pulling the old filter, therefore stirring up the garaunteed crap you had on the bottom of the bowl and it getting thrown through the system. The bowl needs to be drained before you pull the filter than cleaned. There is aways some sort of rust or debris at the bottom....
this guys plea was "but I change the filter every other oil change" and sure enough it came in with a new filter, but it doesnt do a damn bit of good when you dont clean the bowl....
That's bad news right there. It's well worth your time to throw some elbow grease at the bottom of the fuel bowl. It can get expensive to fix!
Discussion Starter · #9 ·
What kind of damage could it have done? I swear my truck has a mind of its own. Sometimes it feels like its running great, sometimes it feels like its lacking power. It didn't have stock filter, I put in stock filter and cap. Would the oem filter restrict a bit more causing small power loss?
Wow that's crazy to think the fuel bowl would get that way. He must have been useing bad fuel or dye fuel. my truck is every bit clean and clear. Maybe cause It only have 57257 miles but I never had to clean anything on bottom even when I rebuilt it two weeks ago.
Stirn Again
CTC What is mill dust
Village Idiot
I am hoping dust from a chicken feed mill.
Kinda looks pond sludge thouh....lol
oh man, the only thing missing is the toilet paper,
your injector nozzles are probably trying to push that gunk out too. hence the mind of its own... clean that bowl and run some cleaner in the fuel for awhile. hope that clears it up. otherwise post back the results.
every fuel filter change I fill the bowl with sea foam. It's as clean as a new one.
I clean mine with carb cleaner.usally a vaccum it first then clean her out with the carb spray. I also only usemotorcraft filters. I'm going to eventualy put an airdog system on it and do away with the stock filter bowl though. Better water seperation and be
I clean mine with carb cleaner.usally a vaccum it first then clean her out with the carb spray. I also only usemotorcraft filters. I'm going to eventualy put an airdog system on it and do away with the stock filter bowl though. Better water seperation and better filtration
1 - 20 of 20 Posts
