1 - 3 of 3 Posts
Powerstroke Expert
Most of the lifted truck owners can confirm, how challenging it is to get behind the wheel without an additional step, so today we're here to introduce you our two brand new running boards for Ford F-Series! Developed by the leading aftermarket manufacturers Aries and DeeZee, they are guaranteed to suit your needs and preferences, providing the easy access to the cab for you and your passenger.
Aries power running boards will be perfect for those looking for innovative design, smooth operation, and improved ground clearance. Being durable, functional, and stylish, they feature up to date Step-within-a-Step design for sure footing no matter the weather conditions. Moreover, all ActionTrac powered running boards are equipped with smart sensors intended for the automated operation to provide you with the additional stepping area when you need it most. Being power-operated, they drop 8" when the door opens and up to 15" below the door sill. For additional safety, footing surfaces are illuminated as well when the doors are opened. Maximum ground clearance during off-roading and hassle-free installation are guaranteed.
ActionTrac Retractable Black Running Boards by Aries at CARiD.com
Notes:
* 1 Pair;
* Material: Aluminum;
* Length: 79" / 83";
* Equipped with smart sensors for safe, automated operation;
* Power step drops 8" when door opens, up to 15" below the door sill;
* Made from durable and non-corrosive powder-coated 6061-T6 aluminum;
* Mounting brackets Included;
* Rated for 650 lbs. static weight capacity;
If you are in the market for maximum safety and comfort, take a closer look at classic running boards with the new design developed by Dee Zee. Made from heavy-duty steel, and coated with the NRT texture black powder coat finish, they will provide you with a durable paint protection and custom design.
6.5" Louvered Black Side Steps by Dee Zee at CARiD.com
Notes:
* Made of heavy-duty steel with a textured black powder coat finish;
* Custom-fit bracket kit for most applications (Sold Separately);
* No drill installation with custom-fit brackets (Sold Separately);
* Looks great with Louvered Sport Bar;
Find the most suitable application for your off-road adventures at CARiD, make sure to browse through the selections of options available for you Ford F-Series on our website:
https://www.carid.com/running-boards.html
Will the Action Trac be available with brackets for OBS fords?
Powerstroke Expert
1 - 3 of 3 Posts
