1 - 8 of 8 Posts
hey I’m new to this forum. I have a 2001 ford Excursion 7.3 4x4 lifted. I have pretty major negative camber on my front passenger wheel. Since this is a straight axle I am led to believe that there is not camber adjustment. I was thinking it was a wheel bearing but there is no wheel play while it is in the air. Could it still be that? I chew through tires very quickly and its time to be fixed. Any help or input would be great. Thanks
Project Shamu
Axle could be bent, ball joints could be bad, or wheel bearing could be bad.
If you verify it's none of these things, then there is a cam bushing you can install in the top ball joint to adjust camber.
PSN intsigator
Wheel bearing or ball joint. Those are about your only to culprits
Sent from my SM-N975U using Tapatalk
PSN intsigator
Dammit Dan beat me to it
Discussion Starter · #5 ·
Wouldn't a bent axle cause a wobbly wheel and vibration instead of a constant negative camber? Would a picture help? I am fairly mechanically inclined but I am only 18 and don't know everything yet
Project Shamu
A bent axle housing will not cause a vibration but it might be difficult to engage the hubs.
You are thinking about a bent axle shaft, which will cause a vibration, but will not cause camber.
Administrator
Pay $80 and have it aligned. If parts are bad they won’t align it and won’t charge you. Change out bad parts and alight it.
1 - 8 of 8 Posts
