1 - 5 of 5 Posts
Construction Babysitter
I very rarely view boost thru my scan gauge, but yesterday morning I started the truck and it was reading -3.x psi boost at idle. My Isspro boost gauge is reading correctly. Both go up and down with normal driving like usual, just the scan gauge reading starts out as a negative number. I am assuming the scan gauge gets its info from the map sensor. Is this an indication my map sensor is going bad? Never heard of these things going bad.
Thanks
Premium Member
are you sure the scan gauge is reading boost and not (kpa?) I know on my truck it would read a constant -14.0 tho but I never set up the gauge to read boost of the pcm.
Chachi
if its in the negative could that be the vaccume psi?
I don't think I actually have negative boost because my real boost gauge is reading correctly. But since my scan gauge is reading what the computer is seeing from the map sensor, I would think a negative boost number could have some effect on how the truck runs.
1 - 5 of 5 Posts
